How to connect the Agilent 8565EC spectrum analyzer via the GPIB (or Ethernet via GPIB/ENET gatway) to the Labview/PC, And to download the spectrum waveform image? Thanks.
Is there a typical setup procedure for Labview and spectrum analyzer?
(3,244 Views)
Use the driver that you can find here or on the driver CD that comes with your copy of LabVIEW. Even though it's called HP8563, it should work with your model. Try the Getting Started VI to get an idea on how to use an instrument driver.
(3,244 Views)
