How to connect three-wire strain gauge to NI 9219
I am wondering how to connect a three-wire strain gauge to the NI 9219 in a quarter bridge. I am capable of completing a connection with a two-wire strain gauge, but am confused as to how the three wire model should be connected.
Thank you in advance.
(3,704 Views)
The datasheet shows.
https://www.ni.com/pdf/manuals/377223a_02.pdf
Page 5.
The 3 wire RTD circuit is equivalent to a 3-wire 1/4 bridge strain gage.
(3,680 Views)
How would this translate to LabVIEW since the connection diagram generated by the software only displays a two-wire connection when a quarter-bridge option for strain is selected?  After connecting the three-wire gauge to the DAQ in the configuration of the three-wire RTD circuit, are there additional settings to adjust on LabVIEW with the three-wire connection?
(3,634 Views)
For the sake of argument, a 3-wire RTD is no different than a 3-wire strain gage.  They are both resistors whose resistance varies based applied external conditions.
I don't know what software diagram you are referencing.
As for additional settings, there might be some.  I can't say because I don't have a DAQ device or sensors with me to test.  But you can try your self and see how it works.  You're not going to break anythingl
(3,625 Views)
