How to connect to a database on a webserver
Hi all,
I am trying to use the database connectivity toolkit, and am having no success.  Using .asp to connect to the database I use the following code:
Set dbInstrumentDB = Server.CreateObject("ADODB.Connection")
dbInstrumentDB.Open "instrumentdb"
On the server, in the ODBC data source administrator, "instrumentdb" is set in the "System DSN" tab to point to an access database.
The error that I get is : "The file provided is not a datalink (UDL) or a file DSN.
Any help would be apreciated.
Jim
Jim
LV 2020
(2,549 Views)
Sounds like you need to create a file dsn instead of a system dsn? This
is done in the ODBC Control Panel applet.
(2,540 Views)
