12-24-2009 06:18 AM
I am vishal.
i have a task in which i have to monitor temperature of different components.
labview platform is used for making software that takes output from thermistor through NI PXI 2503 multiplexer and converts it to digital
using ni pxi5152 digitizer.now i have to control both of this instruments and take values from digitizer.
but the problem is that i don't know which VIs will be used to control these instruments, because i am doing this first time.
I just know that NIDAQmax VIs can be used, but don't know how to use them.
Please some one give me a little bit start for making this program.
thank you.
Solved! Go to Solution.
12-24-2009 09:02 AM
12-28-2009 02:14 AM
thank you, i shall check it.
and contact for any other need.
thanks a lot
