How to control USB using Labview?
Can any one tell me how Can I control USB(actually i want input through USB) devise using Labview?
I tried with "inport.vi" and gave address of my enhanced USB host controller in the address field, but could not satisfy me.
I want to check frequency of TTL signal coming from Function generator.
For that i want to count number of pulses in a specified time.
I have tried with Parallel port, but i could count only for 5kHz frequency signal.
and I want count for signal in 1M Hz range.
Can any one give me example code for taking input from USB ?
Thanks.Smiley Happy
Vishal
(4,834 Views)
If you have time please go through these nice nuggets 1 and 2
Message Edited by nilovers on 04-03-2009 01:44 AM
(4,828 Views)
Look at the tutorial link given here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
It gives introduction to access USB devices (NI and non NI).  Have a look at it and post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(4,826 Views)
