How to control keithley 6221 just to change the frequency of a wave at intervals .
I'm very new to LabVIEW. I'm trying to control keithley 6221 using RS-232.
What I want to do is just to change the frequency of a sine wave at every 30 seconds, and the series of the required frequencies could be input at the beginning.
Does anybody know how can I do it?
I'll be glad to get any help.
Thanks!
(2,441 Views)
NI does not have a LabVIEW driver for that instrument but you might want to check with Keithley.
On the main Instrument Driver Network page are links on developing an instrument driver. There is a wizard (Tools>Instrumentation>Create Instrument Driver Project) as well as the Instrument I/O Assistant. You will need the instrument manual to look up the programming commands. There are example VIs for serial communication.
(2,425 Views)
