How to control ni 9475 by LabVIEW?
I'm using ni 9475 as a relay to on/off an heater. How can I control it according to a cetrain value of temperature?
(633 Views)
You would need another module to measure the temperature. Depending on which cDAQ or cRIO, you can program it to control the heater based on the input temperature.
https://tmesystems.net/
(614 Views)
I did it.
(604 Views)
