05-09-2005 01:39 PM
05-10-2005 11:55 AM
01-11-2011 03:49 PM
I am having the same problems do you know a converter that is actually complient
01-11-2011 05:04 PM
You could try this one but it is really dang expensive.
01-11-2011 05:28 PM
Well it is cheap, but it has a centronics connector on the printer end. So you would need an adaptor to get it to a DB25.
Alan
01-11-2011 05:34 PM
01-11-2011 05:51 PM
And if you really wanted to cover ALL bases you could purchase a "gender bender" then your system would have the ability to work on either end ot the DB25 interface. The OP DID say DB25 but pretty much in this decade you would need a DB9, Oh no more connectors.
Alan
01-12-2011 10:08 AM
That looks like the same kind of thing it only mentions that it is for a printer, I have one like that here only it has DB25 and it doesn't work. I have found one that says it will work of on anything with a parallel port, scanners, bar-code readers, etc. if it works I will post it here. I have found a cardbus that claims the same thing, I will use that for develpement but I cant really deploy with it. I ordered both but I really need usb becouse I am connecting 3 machines and I wanted to route all them to a laptop. If these don't work I will get a tower with 3 parallel ports and be done.
01-15-2014 12:20 AM
hi steve, i also facing the problem when using the USB to parallel port to control output. before this i direct use the parallel port (PC) to control, now im adding a usb to parallel port to control the output (LAPTOP). it is using the device that u recommeded can solve the problem ? what is the function node that used in labview ? thanks. sheng
01-15-2014 02:25 AM - edited 01-15-2014 02:25 AM
