How to control the data rate of a digital write to a port on a PCI-6509
I am using a PCI-6509 to write digital words to a custom digital board. I can generate the proper patterns with the 6509 but the resulting pulse rates are very high (150+ khz) which is very noisy. I know the board cannot have its clock controlled. Is there a simple way to adjust the output rate? I am generating a 1D array and writing this to the device with the NI-DAQmx commands. About all I could come up with is interleaving this array multiple times to stretch the resulting pulse. Anything more elegant, as this seems pretty brute force?
Tom
(2,366 Views)
Hello Tom,
When doing software-timed updates, you can use a delay function in your loop which is doing the DAQmx Write. Increasing this delay should increase the delay between every sample that is written. Because this is software-timed, it is not deterministic so the time between the samples being output might be greater than what you are actually specifying the delay. However, this is not really a disadvantage compared to the current method you are using (duplicating array values to stretch the pulse) because it is also software-timed. I hope this helps!
Eric
DE For Life!
(2,351 Views)
