How to control the graph update (or refresh)
When the YScale.Maximum = 4 and YScale.Minimum = 2 of the XY Graph, I do not want the XY Graph to update (or refresh). When the YScale.Maximum = 6 and YScale.Minimum = 1 of the XY Graph, I want the XY Graph to update (or refresh). How can I do that.
Thank you very much,
Steve
(4,337 Views)
My case is that when data, YScale.Maximum and YScale.Minimum change at the same time, but the graph changes twice, one for data changes, another for YScale.Maximum and YScale.Minimum change. I want the graph to change only once.
Thank you,
Steve
(4,323 Views)
Accepted by topic author Shijie
Like this?
(4,301 Views)
Hi Jeff,
It solved my problem. Thank you very much.
Steve
(4,291 Views)
