11-10-2015 03:05 AM
Hi all, I am a beginner of Labview, I am really not clear about '1D array of waveform (DBL) '. And can anyone tell me how to convert this data type to waveform (DBL).
I'd appreciate any help in advanced.
Regards Sylover
11-10-2015 04:01 AM
11-10-2015 07:20 AM
I am not clear what problem you are having. In posting to the forum, it is usually helpful (for us, in order to help you) if you post some code that you are trying to develop, stating clearly what you are trying to do. Sometimes this is as easy as saying "My input is ... " (and build the input into your code) " and my output should be ...". Be sure to include your code, usually easiest to do by attaching the VI. Do not simply paste a picture of your Block Diagram -- we can't "edit" a picture (unless you know how to make a LabVIEW Snippet) nor can we execute it.
Bob Schor
11-10-2015 08:38 PM
Hi Sylover
In LabVIEW waveform is a cluster, contains 3 elements: t0, 1D array, dt.
Your data source is 1D array, So it won't match waveform type.
You have to change your data souorce to waveform type.
