How to convert 2D array into waveform
Dear All
I have 2D double array of data values. I need it as a waveform with time values attached. Any suggestions?
Aksoy
(6,948 Views)
Hi Aksoy,
why do you create a new thread instead of sticking with your old one?
Don't do this!!!
(6,946 Views)
Because of the title
(6,942 Views)
as you see in the title of my message...
(6,935 Views)
Well, this is definitely a case-in-point for how to not use the forums.  Use PM's for stuff like this, please.
Back to the question:  To get a 2-D array into a waveform, you will need to use a 1-D Array of Waveforms.  Here's what this means:
Each waveform has an array inside of it.  To play nicely with a 2-D array, you should parse the array row- or column-wise and stick each row/column into a single waveform - then create an array of waveforms.  This will encapsulate all of your data.  How is the time stamp integrated into the current data set?
Nathan - Certified LabVIEW Developer
(6,918 Views)
