How to convert AIPD Image to JPEG?
Hi everyone,
I am having problems with (what I thought to be) a simple task.  Using IMAQ Vision package, I want to convert a greyscale (SGL) "*.AIPD" Image to a JPEG.  I will post the code that I thought would work, but I'm obviously not understanding something fundamental to the images because it doesn't work and is giving me..'wrong image type'.
I'm stuck, again, and appreciate any help.
Jonathan
Message 1 of 10
(4,274 Views)
Here's an example .AIPD Image to work with.... (had to compact it cause server didn't recognize extension).  By adding a simple IMAQ image display to that .vi you can see the image
Message Edited by IEC on 09-12-2006 03:58 PM
Message 2 of 10
(4,267 Views)
Jonathon
Try building your VI like this
and see if this works for you.
cheers
David
Message Edited by David Crawford on 09-12-2006 09:55 PM
Message 3 of 10
(4,259 Views)
David,
No, sorry, that gives the same error:
'd:-1074396080'
'IMAQ WriteJPEGFile
  Invalid image type.'
Message 4 of 10
(4,242 Views)
Thats weird it worked OK for me. Try it without using the image type enums.
David
Message 5 of 10
(4,235 Views)
Jpeg is 24 bit image by default.  So you might have to convert image type.
Or simply use bitmap instead of jpeg.
George Zou
George Zou
Message 6 of 10
(4,233 Views)
Good afternoon IEC,
The problem is that the Write JPEG File.VI only supports U8 and U32 image data types.  If you change the U64 enums to U32, then your VI works perfectly!
Cheers,
Message 7 of 10
(4,222 Views)
I tried doing it this way, it worked, though the image was completely black.  This says to me that all of the values from the U64 are too small (which they are, they are all <<1).  Is there a simple way to scale the values to the appropriate range before writing the jpeg? if not, does anyone know what range they should be in so I can do it manually?
THanks,
Jonathan
Message 8 of 10
(4,216 Views)
I have it working, actually, I just need to know one thing more... how do I generate a 'color palette' to use when saving as a jpeg/tiff/etc... from the color palette choices available.   Check the image to see what I mean.
Thanks for all the help!
Message 9 of 10
(4,212 Views)
IEC,
You can use the IMAQ GetPalette VI to generate a color palette for the IMAQ Write TIFF File VI.  It is in the Vision and Motion >> Vision Utilities >> External Display palette.  Please let me know if this is what you are looking for.
Chris
Message 10 of 10
(4,175 Views)
