How to convert Array of Cluster to Spreadsheet file
I´d like to save some diagram data in a spreadsheet file. These data are put together in 1D array with cluster (consisting of 2 elements: both long datatype).
How can I extract the array to save it in a spreadsheet (using LV 6.1).
Thank you for any reply...
reen
Message Edited by reen on 05-20-2005 04:34 AM
(3,139 Views)
You've already place the right function on the diagram. Wire the variable into a for loop (so you can access the clusters) and wire the cluster into "Cluster to Array" and wire the array out of the for loop. You will now have a 2D array.
___________________
Try to take over the world!
(3,124 Views)
and how often should the for loop be running?
(3,123 Views)
thank you, i´ve got it. answer to my last question was: for array.length ->right?! 🙂
(3,114 Views)
Well, I would say as often as your data changes. The loop is only used to do the conversion.
___________________
(3,112 Views)
