How to convert MIBs to snmpwalk output?
I need to develop a monitoring module, but have no access to the actual device I need to develop for.
If I had the device's snmpwalk output - I could simulate the device (e.g., with snmposter) and start the development.
Is there a way to convert the device's MIBs (which I do have) to an snmpwalk output?
Any ideas would be welcome.
Ron.
(2,986 Views)
Are you trying to convert the device's MIBs to an snmpwalk output using LabVIEW?
There is a 3rd party toolkit that may be helpful in this case, however it is not supported by National Instruments.
I would appreciate it if you can provide more information on your application so that we can understand the issue better.
Regards
Arham H
(2,930 Views)
