How to convert Months to ALL CAPS e.g. 5-Dec-2015 to 5-DEC-2015
This has to have an easy solution.
My date indicator returns the format of DD-MMM-YYYY.
I need the MMM to be all caps.
(3,416 Views)
Accepted by topic author ahhah
Haven't you tried the To Upper Case function?
(3,412 Views)
Assuming this is a string, just use the To Upper Case function on the entire string.
(3,411 Views)
Run the string you already have through "To Upper Case".
Norbert
EDIT: Gna, three times the same answer, but mine is the last 😞
Norbert
Expert: Geometry
(3,406 Views)
It's a Time Stamp.
(3,400 Views)
To Upper Case function works.  Thanks!!!
(3,393 Views)
