How to convert NI LabVIEW FPGA VI into VHDL code?
Dear all,
I am looking to convert my NI LabVIEW FPGA VI to VHDL code. I found this below article on the NI website and installed a LabVIEW FPGA IP Export Utility. I need some help with using the LabVIEW FPGA VI IP Export utility to get a plaintext VHDL code.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wxbHCAQ&l=en-IN
Any help would be highly appreciated.
Thanks & regards
Sukumar.
(3,575 Views)
Hi Sukumar,
Please elaborate on your help requirement so that forum users can guide you appropriately.
Note: FPGA IP Export utility is a separate addon and may require additional license
Santhosh
Soliton Technologies
(3,555 Views)
See https://www.ni.com/pdf/manuals/378241a.html
There is an email address at NI that you should write to.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,552 Views)
Thank you for your response,
Before I posted the question in the forum, I sent an email to NI (labview.fpga.VHDL.access@ni.com). I did n't get any response from the NI. So that, i posted here for some help.
Thanks & regards
Sukumar
(3,481 Views)
Did you purchase the license for LabVIEW FPGA VHDL Export Utility? Without such a license all the person monitoring that email address can do is to recommend you to purchase it first. And you need the more expense VHDL variant to export to VHDL source code. The netlist variant only exports to encrypted netlist format. The resulting files are a bunch of unintelligent binary characters. The Vivado tool chain can use them but you can't really see what it does nor make modifications to it.
Rolf Kalbermatter  My Blog
(3,451 Views)
