How to convert UUID of bluetooth to GUID?
Hi
I am trying to connect a bluetooth device to labVIEW. I am using a bluetooth create listener function and it asks for UUID and that it has to be in GUID format. I would be grateful if anyone could kindly let me know how this conversion is possible. I was unable to find an answer to this question so far.
Thank you
T
(7,801 Views)
Hi Tewerz,
You should be able to assign your own GUID.
uuid Identifies the service. You can assign duplicate UUIDs, but National Instruments does not recommend assigning duplicate UUIDs. If a Bluetooth client requests a UUID that multiple services use on a Bluetooth server, the server uses the first UUID it encounters. The UUID must be in GUID format. An example of a UUID in GUID format is B62C4E8D-62CC-404b-BBBF-BF3E3BBB1374
 Here is some information on UUID and GUID:
http://www.famkruithof.net/guid-uuid-info.html
DylanC
(7,778 Views)
I already have a bluetooth module I want to pair with. I use a bluetooth discover and got the address. How do I translate this to UUID in GUID format or these have no relation?
Thanks a lot!
(7,742 Views)
Tewerz,
You need to assign the GUID yourself. You should be able to choose anything you want as long as it is in the format: B62C4E8D-62CC-404b-BBBF-BF3E3BBB1374
DylanC
(7,730 Views)
Hi DylanC
Do you know if is the same proccess to use a laptop bluetooth device?
(7,690 Views)
What do you mean by laptop Bluetooth device? If you are connecting to any device over Bluetooth it should be the same process.
DylanC
(7,672 Views)
