How to convert WV waveform file to tend format
Hi, would appreciate any help to enlighten me how I can convert a *.wv waveform which I generated from r&S software program to TDMS format. Thanks
(665 Views)
Your question does not belong in the example group.
What NI software are you trying to use? Once we know, we can move the post to the right place.
(637 Views)
Hi I'm using labview 2019. I wish to convert WV waveform file created from R&s software into TDMS format. Kindly please advise. Thank you.
(630 Views)
Do you have the full documentation on the WV format, maybe even an example file. Can you read it into LabVIEW? Once you can do that, you can save it any way you want.
(623 Views)
