How to convert a BCD to Decimal?
      I am using a LabVIEW code for Interfacing a channel selection box.In that output am getting is in the format of BCD.I want to convert that BCD to decimal.Can you Plz tell me to convert this BCD to Decimal?
(7,545 Views)
Just read the value of each nibble . each will =0-9. e.g. 0111 =7
(7,542 Views)
Accepted by topic author $agar
You can use the Boolean operators and the Rotate function to select the hi and low nibbles. Use the In Range and coerce function to limit the range of the nibbles to zero through nine.
(7,512 Views)
Thank you Phillip, this was very helpful and worked great!
(4,104 Views)
