How to convert a .aipd file to a .txt file ?
I would like to convert a .aipd file to a .txt file.
How can I do that ?
Thanks.
Xunil.
(2,882 Views)
AIPD is the National Instruments proprietary graphics format so I'm not sure what you would expect to get if you converted it to a text file. Can it be done? Possibly by reading in the data, converting to 8 bit and saving as text. Much of it will be undisplayable (non-ASCII) characters.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,863 Views)
This link might give you help on converting to 8 bit
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3D8F956A4E034080020E74861
P.M.
Putnam
LabVIEW Champion
(2,862 Views)
