How to convert a cluster of 2 elements to a 1-d array of cluster of 2 elements?
I'm basically trying to plot a polar plot.  I have 2 sets of dynamic data, theta and the magnitude.  I've tried using a bundle to get an output cluster but i get this message: 'The type of the source is cluster of 2 elements.  The type of the sink is 1-D array of cluster of 2 elements.'  Could anyone give me any advice?  I apologise if its a dumb question I am very new to Labview!
Cheers
(5,004 Views)
Accepted by topic author lpaza
Insert a "built array" of height=1 between the two.
(4,994 Views)
i am having same problem if u solved this plz send me solution...i tried build array but its still having problem...plz help me..
(3,871 Views)
The amount of help to expect is roughly proportional to the amount of code you post.  Post what you've tried so far.
Bill
CLD
(Mid-Level minion.)
(3,866 Views)
