How to convert a string to visa resource name
@crossrulz wrote:
@RTSLVU wrote:
@billko wrote:
Only if you have an aversion to coercion.  😉
IMHO: Coercion dots are a sign of failure 😛
That's a little extreme.  Coercion Dots are red flags to issues, not a sign of complete failure.
No it means *I* have failed, regardless of if the program works.
I have to add way back when we were moving from LV5.1 to LV 6i there was a lot of things the would no longer work after importing them into LV 6i because coercion of this or that was no longer supported.
A lot of code had to be rewritten and I don't want to ever go through that again.
=== Engineer Ambiguously ===
Message 11 of 17
(1,477 Views)
In newer LabVIEW versions you can use the "Coerce to Type"
It coerces without a dot. 🙂
mcduff
Message 12 of 17
(1,465 Views)
mcduff
Is that the application of a "gentle" coercion?  😄
Bill
CLD
(Mid-Level minion.)
Message 13 of 17
(1,462 Views)
Sure, LV 5 -> LV 6 was painful; and so was LV 7 -> LV 8.  But since then upgrades have been smooth.  Personally, I would rather have coercion dots than extra code that does exactly the same thing.
Message 14 of 17
(1,453 Views)
As long as coercion always works the way you want it to, I guess that's okay...
But I don't want to rely on something that is out of my control to always be the same when it's simple to do it the right way from the start.
Message 15 of 17
(1,448 Views)
There's some instances where the implicit coercion is faster than an explicit one. I guess it has something to do with memory copies, otherwise it makes no sense.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 17
(1,385 Views)
The only place I know for sure is when debugging is on (additional hooks needed for the extra wire to be probed, etc).
Message 17 of 17
(1,383 Views)
