How to convert an AVI frame to an image data cluster ?
Hi everybody,
I have previous VIs that manipulate pictures (image data cluster) readen from JPEG files. I'd like to use these VIs to analyse individual frames from an AVI file.
How can I connect the image out of the IMAQ AVI read.vi to the picture input of the Draw Flattened Pixmap.vi?
Thanks for helping,
Olivier
(4,344 Views)
Hi Olivier,
You can use IMAQ ImageToArray to convert your IMAQ Image into a 2D array, then use IMAQ Draw Unflattened Pixmap to convert to a picture. Alternatively, you could save each AVI frame as a JPEG (or just save all your images as JPEG to begin with, as in this example) and use your current VIs to read and manipulate the images.
Daniel H.
Daniel Hays | Test Software Business Manager
(4,327 Views)
Thanks for the tip but, in my implentation, it generates that the no picture can be manipulated. Could you tell me where is my mistake?
Olivier
(4,317 Views)
Accepted by topic author OD
George Zou
(4,306 Views)
Works perfectly!
(4,302 Views)
