How to convert an array of 2d booleans into a single large 2d boolean element with all the elements of array one after the other
(2,749 Views)
Do you mean using something like this ???
Nghtcwrlr
(2,716 Views)
Hi rainaby,
maybe you should explain the difference between "an array of 2d booleans" and "a single large 2d boolean element with all the elements of array one after the other"!
Can you show pictures or a VI with some front panel elements to explain what you want?
(2,712 Views)
Why do you start an unrelated thread, if this question is directly related to this ongoing question?
Please keep it all in one thread!
(2,694 Views)
