How to convert an array of string elements to a cluster with named elements of different datatypes?
I'm looking for some help with converting an array of string elements into a cluster with named elements of different datatypes.
I'm importing data from an Excel spreadsheet.  It is coming into LabVIEW as 3 separate arrays (of Strings): 1) Variable name, 2) Datatype (three possibilities Int, DBL, String) and 3) Value, with the indices in each array corresponding to a separate variable (I have approxiamtely 180 variables to import).  My end goal is to convert the "Value" string array into a cluster.  But I want the datatype to be correct in the cluster and I also would like the name of the elements in the cluster to correspond with the "Variable Name" string array so that I can use the Unbundle by Name function in my main VI.
Please see the attached a SubVI for more details.  I made the size of the imcoming arrays 5 elements for simplicity.   I realize that owned labels cannot be changed during runtime and I don't think that I need to do this.  I just want to use the output cluster (mostly the unbundle by name) to help with designing my main VI.  I will need to 'read from' and 'write to' the cluster during runtime but I will not need to change the element names.
I was also wondering if there a better way to import the data from Excel?  Is there a way to import directly into a cluster right away rather than bringing everything in as strings?  I've attached a SubVI showing how I am currently bringing in the data (found it on the forum somewhere).  It comes in as a 2D array, which I split into the 3 separate arrays that I mention above.
I'm open to any and all suggestions.  Thank you very much.
-Mike
Brown
The more I know...the more I don't know
(4,482 Views)
Accepted by topic author Brown@KTR
Instead of trying to create a cluster, I think I would just use Variant Attributes.
GCentral
(4,442 Views)
Thank you.  I have never used variants before so I am new to this concept, but I can make this work.  It will take a little more work on the back end to pull the right variable (rather than just selecting from the unbundle by name function) but that's ok.
Cheers,
Mike
Brown
(4,422 Views)
