How to convert cluster containing bytes into array of bits?
I have a cluster which contains field as follows:
preamble (4 bytes) | SYNC word 1 (2 bytes) | SYNC Word 2 (2 bytes) | Packet_ Counter (4 bytes) | Payload
I would like to convert this struct into a bit stream. I am attaching VI block diagram as screenshot.
When I run the program in the display panel, I do not get expected result. The result I got is completely different from result I was expecting to get.
Could you let me know what I might be doing wrong here?
Thank you.
Edit 1: Sorry for being so vague. I tried to find the source of the problem. I noticed that after flatten to string and string to byte array conversion, some unwanted information is being added. The source of the problem is either flatten to string or string to byte array conversion. But I don't know what the problem is....
Message 1 of 18
(3,273 Views)
Accepted by topic author labview_wannabe
1. Your Preamble is an array of 16-bit values.  Is that a 2 element array or is it supposed to be 4 U8 values?
2. You are putting your payload before the packet counter.
3. One of the issues with the Flatten To String is that it will prepend the array size.  There is a Boolean input to turn that off.  However, that input is ignored for anything inside of a cluster.
4. Your converting to a Boolean string can be greatly simplified by using Reverse 1D Array and a Format Into String inside of a loop.
Message 2 of 18
(3,240 Views)
Hi @crossrulz,
thank you very much for responding.
Quick question though:
1. As you can see in the screenshot in the question, the sub VI I created tells me that the input is 16 bit whereas in the main VI, the array is specified as U8. How do I correct it? How do I make the sub VI read the input as 4 u( array instead of 2 U16 array, as it is reading now?
2. Yeah..... my bad!!
3. Why did you do reverse 1D array there? Is it because the LSB and the MSB get interchanged somewhere? Where does it happen?
4. Instead of build array, if I want to use clusters, how do you propose we do that?
Thanks again.
Warm Regards,
Message 3 of 18
(3,211 Views)
1. Just right-click on the control and change the representation to U8.
3. I reversed the array because of the way you were building the string in the FOR loop of your main VI.
4. Why do you have to use a cluster?  You will have to have an array of bytes of some sort (an array of U8 and a string are literally the same format under the hood) in order to do the ASCII conversion.
Message 4 of 18
(3,195 Views)
One last question:
How do I convert the string at the end into array of bits? Is it string --> U8 --> Num_to_array --> Bool_to_(0,1)? Or is there a smarter way of doing it?
Message 5 of 18
(3,134 Views)
I skipped that part and just took the byte array straight to your ASCII Binary format.  So I guess the real question is what format do you actually need the data to be in.  Be extremely specific or we will likely be talking past each other.
Message 6 of 18
(3,124 Views)
So I need something like bitstream in I8 format. If I have string in the form "10001" then the corresponding bitstream must be in the form 10001. Further simulations (like modulation etc) are then done on these bistreams.
I tried to do it on my own. The main file is
And the sub VI is
When I run the main VI, I get string output as
I have verified that the string in the sub VI is accurate. So some encoding error happened when performing byte to string conversion.
Also, if I need to verify the bits at the receiver and parse the bitstream, how do I do it? I know that I need to do auto correlation and then peak detection. But how do I parse after the auto correlation? That was the main reason I wanted to use cluster, because it was easier to parse the bitstream into individual fields. Now with just byte array, how do I do that?
Message 7 of 18
(3,109 Views)
Hi wannabe,
why don't you attach the VIs? We cannot edit/debug/run images of code in LabVIEW!
Why are there so many coercion dots?
Message 8 of 18
(3,103 Views)
@GerdW wrote:
Hi wannabe,
Here are the vi files. I think the coercion dot mainly due to type mismatch. my bad.
Message 9 of 18
(3,097 Views)
Hi Gerd,
The first file lab1_commlabs_is_fun.vi is the main VI. The other two are sub VI. packet_formatter.vi combines all the byte array into a single array of bytes and then convert it into bits. I am trying to read this bitstreams as string in the main VI where I am getting errors.
In packet_parser.vi file I am trying to parse the bit array into individual fields. I am trying to detect the preamble and then extract the payload. Here too, I am not sure how to proceed. I did try to perform detection by myself, but as you can see, I did make some mistake.
if you need any other information, please let me know. It is my first time using LabView, so if you want me to raise this as a separate issue, please let me know.
Warm Regards,
Message 10 of 18
(3,059 Views)
