How to convert complex equation in LabVIEW without mathscript
Here is what ChatGPT made for python, you can call a python node in labview, or try and reproduce this code with labVIEW
CLA
Message 11 of 15
(1,232 Views)
I suggest to test if that code produces the expected output...
Message 12 of 15
(1,190 Views)
@mrdas9820 wrote:
Hello prof,
The blue squares are just to make it easier to group the steps, it is not for code function.
it looks like you want to use a sequence instead of blue squares... use it so that the local variables are written properly
I don't understand why you use the z*, it looks like you are guessing...
@mrdas9820 wrote:
For this for loop, I am still confused. How is the formula converted into a block diagram?
identify the input variables you already have
e.g.  Yᵢᵢ, which is an array and it looks like you already have Yᵢⱼ but it is named "ADMITTANCE (yji)"
you have to clearify your name-ing, otherwise this is a waste of time...
Message 13 of 15
(1,180 Views)
Please help me to convert this matlab code into block diagram in LabVIEW:
iter=0;
maxerror=10;
while maxerror >= accuracy & iter <= maxiter
iter=iter+1;
for n = 1:nbus;
YV = 0+j*0;
for L = 1:nbr;
if nl(L) == n, k=nr(L);
YV = YV + Ybus(n,k)*V(k);
elseif nr(L) == n, k=nl(L);
end
end
Sc = conj(V(n))*(Ybus(n,n)*V(n) + YV) ;
Sc = conj(Sc);
DP(n) = P(n) - real(Sc);
DQ(n) = Q(n) - imag(Sc);
if kb(n) == 1
S(n) =Sc; P(n) = real(Sc); Q(n) = imag(Sc); DP(n) =0; DQ(n)=0;
Vc(n) = V(n);
elseif kb(n) == 2
Q(n) = imag(Sc); S(n) = P(n) + j*Q(n);
if Qmax(n) ~= 0
Qgc = Q(n)*basemva + Qd(n) - Qsh(n);
if abs(DQ(n)) <= .005 & iter >= 10 % After 10 iterations
if DV(n) <= 0.045 % the Mvar of generator buses are
if Qgc < Qmin(n), % tested. If not within limits Vm(n)
Vm(n) = Vm(n) + 0.005; % is changed in steps of 0.005 pu
DV(n) = DV(n)+.005; % up to .05 pu in order to bring
elseif Qgc > Qmax(n), % the generator Mvar within the
Vm(n) = Vm(n) - 0.005; % specified limits.
DV(n)=DV(n)+.005; end
else, end
else,end
else,end
end
if kb(n) ~= 1
Vc(n) = (conj(S(n))/conj(V(n)) - YV )/ Ybus(n,n);
else, end
if kb(n) == 0
V(n) = V(n) + accel*(Vc(n)-V(n));
elseif kb(n) == 2
VcI = imag(Vc(n));
VcR = sqrt(Vm(n)^2 - VcI^2);
Vc(n) = VcR + j*VcI;
V(n) = V(n) + accel*(Vc(n) -V(n));
end
end
maxerror=max( max(abs(real(DP))), max(abs(imag(DQ))) );
if iter == maxiter & maxerror > accuracy
fprintf('\nWARNING: Iterative solution did not converged after ')
fprintf('%g', iter), fprintf(' iterations.\n\n')
fprintf('Press Enter to terminate the iterations and print the results \n')
converge = 0; pause, else, end
end
Message 14 of 15
(1,092 Views)
iter=0;
maxerror=10;
iter=iter+1;
for n = 1:nbus;
YV = 0+j*0;
for L = 1:nbr;
end
end
Sc = conj(Sc);
if kb(n) == 1
Vc(n) = V(n);
elseif kb(n) == 2
if Qmax(n) ~= 0
else, end
else,end
else,end
end
if kb(n) ~= 1
else, end
if kb(n) == 0
elseif kb(n) == 2
VcI = imag(Vc(n));
end
end
end
Moving to MATLAB Script Nodes from MathScript Nodes in LabVIEW – Benchmark Examples - NI Community
CLA
Message 15 of 15
(1,079 Views)
