How to convert from string to double?
I have a concatenated string that needs to be converted to double to be used in a subvi. How can I convert this? I'm using LabVIEW 7.0. Thanks!
(5,056 Views)
There is a function in the String>String/Number Conversion subpalette that does the job. Not sure that this is the answer you are expecting, since I don't see what the "concatenated" info is hiding...
See the attachment
CC
Chilly Charly    (aka CC)
(5,044 Views)
I wasn't sure if it being a concatenated string had to do with anything, I just thought I'd mention it in case. I couldn't open the file because it was created with LabVIEW 7.1, and I'm using 7.0.
(5,041 Views)
We need to know more about your string. 😉
(1) Is is a human readable string consisting of the decimal numbers characters 0..9, a possible decimal point character and/or the character "e"?
(2) Is it a string of 8 binary bytes representing the DBL in binary format?
For (1) use one of the string functions, e.g. "Fract/Exp string to number" or "scan from string (with %f as format)", etc.
For (2) use typecast with "DBL" as type. If the string is in little-endian, you need to reverse it first.
(edit: typos)
Message Edited by altenbach on 03-19-2005 02:08 PM
(5,041 Views)
Sorry !
Here is a 7.0 version
CC
(5,019 Views)
I got it working. Thanks for the help!
(5,016 Views)
