How to convert .html report into .pdf?
How to convert .html report into .pdf? (can i have any vi for that)
(3,307 Views)
Best bet is to look for a command line tool or .NET dll for that.
A real conversion of everything HTML supports would be very hard (I doubt it exists).
A screenshot of the HTML rendered in a browser would be almost trivial.
A conversion of simple HTML tags (<B>, <I>, <H>, etc.) is doable.
There's no single VI that does this. You'd need at least a tool that does this, or a PDF and HTML library.
If the report is generated in your code, it's (much) easier to generate the PDF directly.
(3,262 Views)
1. Read HTML in Edge
2. Print to PDF
3. Profit
Qestit Systems
Certified-LabVIEW-Developer
(3,257 Views)
Wander if AX or .NET could automate that?
(3,251 Views)
no
(3,239 Views)
@krish77 wrote:
no
Sure? Why not?
(3,227 Views)
