How to convert .ini file to cluster?
Hello!
I have a .ini file and would like to convert it to cluster and use the data within LabVIEW
The tables/arrays are dynamic and can be larger or smaller, I tested with several ways and could not solve the situation to meet all cases
I've attached the .ini file and the Vi I'm building
Message 1 of 15
(2,435 Views)
Please do a "save for previous" (LabVIEW 2020 or below and attach your VI again.
Clusters are fixed size and defined at compile time. Why does it need to be a cluster?
Maybe you can define a cluster will all possible fields, then only use some of them?
Message 2 of 15
(2,424 Views)
Oh, I asked if it was a cluster because of how easy it is to work with
But if there's another way I don't see a problem
Message 3 of 15
(2,416 Views)
So what exactly do you need at the end?
I was confused by your convoluted code, here's maybe a simpler way to read the data as 2D array for further processing.
How is this data used later and how does your array diagram constant fit into the equation?
One possibility would be to build a MAP (key/value pairs)
Message 4 of 15
(2,400 Views)
It looks like whoever wrote the INI file is using MGI's Read Write Anything. You can use their library to convert the ini file to a cluster. You will need to define the cluster that you want from the INI file; it is supposed to be the same cluster that was used to write the file. I do not remember how it handles missing fields, errors, etc.
Message 5 of 15
(2,363 Views)
Hello
you can't create a cluster from a text file. Or you need scripting.
But you can manually create a cluster, and the manually set every value.
You can read INI file with Labview VIs "Configuration":
And this example :
  • labview\examples\File IO\Configuration (INI)\Configuration (INI) File.lvproj
Message 6 of 15
(2,313 Views)
This is a job for LabVIEW Scripting.  It absolutely is possible to get LabVIEW to (a) look at a data structure, (b) analyze and figure out what types it contains, (c) use "other means" to create meaningful "Cluster names" for the putative Cluster Elements, and then (d) create the Cluster.  I did this in one of my first major LabVIEW projects, taking an Excel WorkSheet whose column headings became the "name" of a Cluster element and whose type was determined by analyzing the contents of the data contained in that column (from a Master WorkSheet that had "sample data" that could be analyzed to determine if it was a Dbl, I32, Boolean, String, or (other things I don't remember now).  I made a Cluster (>100 elements!) that I could read an entire WorkSheet row into, and then when I needed, say, "Elevation", I would Unbundle by Name and get the Dbl value it contained.
Go to the Web and search for LabVIEW Scripting Tutorial.
Bob Schor
Message 7 of 15
(2,299 Views)
I second the motion for MGI Read Write Anything which I've been using for almost 20 years now.
Fields that are missing in the .INI file will either be assigned the datatype's default value (0, False, empty string, etc) OR you can optionally provide a cluster of default values as an input wire.
Remember to make your cluster into a typedef!  (Right-click cluster boundary, "Make Type Def", then save.)  Beware if manually editing -- it does not like extra whitespace around the '=' assignment.
-Kevin P
Message 8 of 15
(2,278 Views)
Really, the .ini file was created using MGI Write Anything
I was trying to convert the ini data using that (MGI Read Anything), but i couldn't
Updated files, with the creation of typedef
Message 9 of 15
(2,274 Views)
You can use my Ini-handler
Solved: Re: Read/Write INI Cluster OpenG - NI Community
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 15
(2,234 Views)
