Hi Ross,
Yap, I understand that there is a peak detector.vi in LabVIEW 5.0, but the peak detect.vi in LabVIEW 6i (with a peak detector.vi as sub. vi) is not supported in LabVIEW 5.0. What can I do?
Is there other method to replace the peak detect.vi for LabVIEW 5.0?
I will like to cpature the peak voltage and set a threshold. How can I make use of the peak detector.vi to perform this?
Thank you.
Mary
