How to convert the graph to gray scale
Hi
I am using MS 1.1 version, I need to take the print of the graphs which is provided by NI. The problem here is that i need the GUI to show the graph in multicolor environment, but when i am going to print it on a paper, i should be able to convert into gray scale. Can you kindly suggest me what should be done to achieve this?
Is there any features which present in MS which can help an user to decide this conversion at run time.
Thanks & Regards
Sandy
(2,509 Views)
Hi Sandy,
I hope you are doing well today! What is MS? You should be able to use the invoke nodes of the graph controls to export an image and do some manipulations to it. Can you be more specific as to what you want to do and what kind of programs you are going to use?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,491 Views)
