How to convert timestamp of a waveform in string?
Hello!
I collect voltage as a waveform and I would like to convert the waveform in a string and save it in an ACSII file. For this I am getting waveform components and converting Y, and dt as strings in separate columns. I would also like to save "t0" but I don't seem to find the solution...
Could anyone help?
Thanks!
(3,485 Views)
You could save the waveform straight to a file with Export Waveform(s) to Spreadsheet File.vi
If that is not to your liking, you can convert the timestamp to a pair of strings (one date, the other time) with Get Date/Time String on the Timing pallette.
(3,482 Views)
Thank you Jason.
(3,475 Views)
