How to convert two 1-D arrays(containing decimal numbers) to single 2-D arrays?
Like I want the 2 Columns of 2 different 1--D arrays to combine in 1 2-D array..
EG-
array 1-         array 2-                               output 2-D arraya-
1                      5                                                  15
2                      6                                                   26
3                      7                                                   37
4                      8                                                   48
PS- im reading the two 1-D arrays from a graph so they may contains decimal upto unknown number of places.
(2,759 Views)
Build Array function.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(2,754 Views)
Accepted by topic author ananrathi13
Even I would suggest what Ravens told. Before posting these kind of questions in the forums you must atleast give a little effort in going through the LabVIEW basics study materials. After that if you get any kind of doubts or troubles, all of us are waiting eagerly to help youe..:)
For the time being may be this is what you were looking for.
Nitzz
(Give Kudos to good Answers, Mark as a solution if your problem is Solved:smileywink:
(2,749 Views)
