How to convert week Number into Month for a a specific Year.
I have week Number 44 and year is 2022.
How to convert this week Number into month??
Message 1 of 11
(5,097 Views)
Hi Risuraj,
By applying some simple math!
What have you tried?
Where are you stuck?
Why don't you attach your current VI?
Generic advice: we don't solve your homework for free…
Message 2 of 11
(5,078 Views)
This problem cannot be solved using the information given. Please refer to https://en.wikipedia.org/wiki/ISO_week_date
Alternatively, you could approximate the month like this: (44/52*12)+0.5. This turns out to be end of October and seems to be a decent approximation.
Message 3 of 11
(5,048 Views)
I agree.  You'd think it is a trivial thing, but the definition of the number of weeks in a year is surprisingly complicated.
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(5,011 Views)
I once thought it would be smart to just let .NET do the heavy lifting. As it turns out, even Microsoft did not get it right the first time: https://learn.microsoft.com/en-us/archive/blogs/shawnste/iso-8601-week-of-year-format-in-microsoft-n...
Message 5 of 11
(4,985 Views)
A Gregorian year is 52.1775 weeks long,
whereas a tropical year is 52.1773768865 week long.
Message 6 of 11
(4,964 Views)
On top of all the complexities mentioned, I'm sure a week can be in two months.
Message 7 of 11
(4,909 Views)
It can.
The answer can be found here but it uses .NET to do the math. I've done it but I am sure you can use LabVIEW to get the answer without using .NET Constructor/Property/Invoke nodes.
Message 8 of 11
(4,871 Views)
@Eric1977 wrote:
It can.
Well, not that much wrong with .NET...
The calculations get complex at CultureInfo.CurrentCulture.Calendar, there you get rules for the week numbering... Guess you could dig into that too.
Here's an untested conversion of the start:
Message 9 of 11
(4,844 Views)
Accepted by topic author Risuraj
Your code is MUCH MORE ELEGANT than mine is. 😂 But, I've used .NET to do all the work and followed the C# code in the link I provided.
Message 10 of 11
(4,825 Views)
