How to copy one plot from a waveformGraph or a chart to an other waveform Graph in run time?
Hello...
I need to copy a chart og waveform graph to another waveform graph in runtime, but its not working, I tried to copy froma chart to a graph by using the history property, but it didn't work coz it just runs the data from the chart the same way in the graph. I sort off want a standing plot from the chart to graph. or from graph to graph. it doesn't matter.
The meaning by that is that I want to check the data , by using the graph pallete and the cursor pallette.
But I can't do that if the source graph  is running.
so by copieng the graphs data to another graph. i can check the data all the time i want.
I Hope someone out there Understand what I mean. My english is not that good.
Thanks.
Zamzam
HFZ
(3,435 Views)
If I understand you correctly, you want to take a snapshot of the data in the chart and copy it to a graph. Unless you make this part of a Boolean operation, then you will get constantly changing data in the graph. Add a front panel Boolean and a case statement or use the event structure to copy only when the button is clicked.
(3,427 Views)
..Yeah
something like that. the data chart is running in srcoll mode so the data are shown for only a period of time, by this i mean that ex. i you can only see a period of 200 samples, but not the hole data that allready are in the back ground of the chart.
So here... can I coby all the data that allready has past. i suppose i got to copy the history data of the chart to get all the data! ?
zamzam
HFZ
(3,423 Views)
Hi again, I maked this VI, and it works, but i cant really get the X- scale time with it, any suggestions.!
Zamzam
HFZ
(3,420 Views)
Got it
Thanks for help !!!
That site is Greeeeaaaaaatte
HFZ
(3,417 Views)
Ooouupps forgot to attache file!!
HFZ
(3,413 Views)
