How to copy string to clipboard w/o keystroke?
I want to copy short strings into another program.
Currently I write to a String Indicator, highlight with the mouse, then copy.
Is there a way to write the string directly to the OS's clipboard?
(3,362 Views)
If you're using windows, you can use Chilly Charly's attachment here.
It has VIs for copying strings to the clipboard.
___________________
Try to take over the world!
(3,346 Views)
You could also try this attachment
Joe.
"NOTHING IS EVER EASY"
(3,331 Views)
How about copying a control or indicator impage to the clipboard?
(3,320 Views)
Take a look Image Toolbox at:
http://www.geocities.com/gzou999/imgtool.htm
George Zou
(3,311 Views)
Thanks, Chilly's code worked.
(3,297 Views)
