How to copy the XY graph on labview front panel and insert into Excel using labview
Hi all,
The XY graph display on LV front panel after test. How can I copy this XY graph and insert into excel file?
Thank you very much for your help.
Khanh
Message 1 of 16
(5,829 Views)
If I understand correctly, then you should be able to do this a couple of different ways:
Option 1
Right click on the XY Graph and choose Export --> Export Data to Excel
Option 2
1. Right click on the XY Graph and choose Export --> Export Data to Clip Board
2. Open Excel and paste the data
Message 2 of 16
(5,819 Views)
Thank you very much for your reply. I can manually copy and paste the XY graph into excel, but I would like to do it by labview code since data already save in excel by labview test program.
Message 3 of 16
(5,811 Views)
@KPRO wrote:
Hi all,
Khanh
Depends on what you want out of it.  A picture?  The data?  No longer applicable...
Bill
CLD
(Mid-Level minion.)
Message 4 of 16
(5,809 Views)
I would like to copy the picture of XY graph to insert into excel. Will labview support this?
Message 5 of 16
(5,797 Views)
Do you specifically need it in Excel or would a separate bmp or jpg/png work?
Message 6 of 16
(5,797 Views)
I refer to insert it into excel since report is in excel format, but if it's too hard to do so I can save it in another format.
Either way, will labview support this? Anyway, thank you very much for your quick reply.
Khanh
Message 7 of 16
(5,793 Views)
If i understand the question, this is easily done.  Right-click on the terminal of the graph in the wiring diagram, and select create->invoke node->Export Plot Data To Excel.  You can also select "Export Image" if this is what you want.
Message 8 of 16
(5,790 Views)
Khanh
You are already using the Report Generation Toolkit?  There is the "Append Control Image to Report.vi" that would make this easy.
Message 9 of 16
(5,786 Views)
Thank you, I can use "Export Image" option but I can not find "Export Plot Data To Excel" option. I am using Labview 8.6, does it have Export Plot Data To Excel option?
Khanh
Message 10 of 16
(5,776 Views)
