How to correct Contour Plot lines?
I am trying to use a contour plot to display a simple set of Z values per an XY grid.
Is there a property setting to display the info correctly or is this an issue with the contour plot lines themselves?
Attached is a sample VI with a set of data that shows the problem.
Here is the data looking good in Excel.
Message 1 of 1
(1,507 Views)
