How to correctly get timestamp on compactRIO?
I'm trying to log time for each data point I write to a text file on a cRIO-9056 using LV2020. However, after formatting the timestamp the hours and minutes aren't making much sense. I thought by going into MAX and setting the time on the cRIO and saving it would fix any sort of time issue? Using format into string gives me 24hr time, but the minutes don't match up? Weird
Code
Values displayed
cRIO time settings in MAX
(2,021 Views)
Ok sorry, I just caught the issue with the minutes. I was using lower case and that was the month of the year lol. But that still doesn't explain why after formatting the time I get 5pm instead of 10am?
(2,019 Views)
Accepted by topic author David99999
Alright, it was something really simple and stupid. I changed the time in NI MAX and saved it, but I still needed to restart the cRIO in order for the changes to take affect. Everything is good now. Leaving this here in case someone stumbles onto this in the future 🙂
(1,994 Views)
