How to correctly use LabView with Kvaser hardware
@azadplc007 wrote:
Is there anyway I can get CanOpen library or VIs for Kvaser hardware?
Kvaser does not have any CanOpen specific VIs since all Kvaser CAN hardware works at the raw CAN frame level.
You may be able to put a layer between the NI CanOpen VIs and the Kvaser VIs, but I have not tried this.
Another option would be to look at one of Kvaser's Technical Associate's CanOpen stacks.  You could then create a wrapper VI llb for the CanOpen stack to use in LabView.
Troy
Message 11 of 11
(707 Views)
