How to count double sum in labview
@Moony wrote:
Hi all. I did some changes and attach my version of solution, but it have errors, because I get array of sum in the same values.
On a side-note, you should never wire the N of FOR loops if you are autoindexing over arrays. If you don't wire N, LabVIEW will loop over all elements of the input array, and thus automatically adjust for the correct number of iterations. Delete these blue diagram constants!
Message 21 of 27
(1,676 Views)
Thanks altenbach. Your advices are very important and useful, because I'm beginner in Labview.
Thanks sooooooo much.
Message 22 of 27
(1,672 Views)
A little question: How to write in labview 10^(-23)???
Thanks in advance.
Message 23 of 27
(1,668 Views)
Hi Moony,
10^-23 is usually written as 10e-23 - as is done also in common textual programming languages...
Or more RubeGoldbergish:
Message 24 of 27
(1,666 Views)
Thanks so much for reply, GerdW.
P.S. I'll give you Kudo with great pleasure, but I don't know how 🙂 Give the way 🙂
Message 25 of 27
(1,660 Views)
Hi Moony,
to give Kudos you simply click the yellow star button next to the Kudos counter.
But AFAIK there was a limit: you have to have a minimum number of posts in the forum to be allowed to give Kudos!
Message 26 of 27
(1,656 Views)
OK, THANKS.
Message 27 of 27
(1,651 Views)
