How to create a DAQmx task in LabVIEW ?
I want to create a new DAQmx task in LV. I've used 'create new task' VI in LV. Bt I want to see the created task in MAX task list also.
There is no hardware device connected. Its just simulation.
(4,520 Views)
Accepted by topic author RJ_15
Use DAQMx Save Task.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/DAQMx%20Save%20Task/
Jim
(4,502 Views)
Here's a driver we use.  The design intent is to make sure the software provides the tasks that we need so it's not dependant on resources already existing.
Jim
(4,497 Views)
Thnx a lot. It solved my purpose. 🙂
But I cudn't locate this VI in my functions pallette. I'm using LV 2010.
And I can't the Driver VI also. I think its some higher version. Can u sort out dis problem ?
Runjhun.
(4,491 Views)
Runjhun.
(4,491 Views)
Did you find it?
Jim
(4,483 Views)
Yup. Thnx again 🙂
Runjhun.
(4,475 Views)
