How to create a Global Variable through the Project Explorer
Hi Everyone!
I know how to create a global variable (in a vi through the functions pallette....),
but i am missing a way to create one via the Project Explorer.
Is this a missing feature or just that documentation (and intuition from myself) is missing?
It would be very handy.
THX for your time and hopefully answers.
jwscs
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 1 of 9
(7,849 Views)
Hi jwscs,
why do you need global variables at all?
I haven't created them for years now…
Message 2 of 9
(7,840 Views)
You can create shared variables from the project, but not globals.
Why do you need to create new global variables from the project? If you're working with enough globals to need this functionality, you're probably using too many.
Edit: I even looked in the New menu and didn't see it. Smiley Embarassed
Cheers
Message 3 of 9
(7,835 Views)
nice answer .. mr. deflect 😛
i just needed a container for my config settings, accessable globally,
and changeable.
and found it tedious to first start some .vi and create the global.
possible race-conditions don't matter in my usecase.
:cheers:
Message 4 of 9
(7,830 Views)
and changeable.
:cheers:
I'm of the unpopular opinion that if you know the global variable will be the easiest way for you to do one thing and you're not over-doing it, go for it.
But why do you need to do it from the project explorer? You only need to create the global variable once and then you can find it in the project. You'll need to make a VI to access the global anyways.
Cheers
Message 5 of 9
(7,823 Views)
Accepted by topic author jwscs
Right-click My Computer > New > New... > Select Global Variable.
EDIT:  Although I do agree with Gerd (he's probably asking why you need it so we can recommend a better way Smiley Wink), I do use them very occasionally in simple Write Once -Read Many (WORM) applications like setting overall program security levels on initialization to be read later but NOT modified.  I know it would be better to do a proper Class,  Functional Global Variable (FGV) or Action Engine (AE) but globals ARE convenient and safe IF used wisely.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 6 of 9
(7,820 Views)
@niquist thx .. i've never got that far 😉
@everyone else: i see your points, but as i stated race-conditions don't matter in my use-case,
but some examples what you use instead would be appreciated.
Message 7 of 9
(7,811 Views)
One powerful option to globals is the Action Engine:  http://forums.ni.com/t5/LabVIEW/Community-Nugget-4-08-2007-Action-Engines/td-p/503801
Message 8 of 9
(7,803 Views)
jwscs wrote:  but some examples what you use instead would be appreciated.
It really depends on what you want to do with the global variable.
I really like them for "constants": values you use everywhere and they do not change during the course of the program.
But since we are mentioning race conditions, I recommend you give this a quick look: https://decibel.ni.com/content/docs/DOC-41734
Message 9 of 9
(7,776 Views)
