How to create a VI with variable number of parameters like in Index Array
I would like to create a VI that have 2 "static" inputs, and as many outputs as "dynamic" inputs, exactly like "Index Array" VI.
Example:
Case 1: 1 dynamic parameter
-parameterA input
-parameterB1 input
-parameterC1 output
Case 2: 3 dynamic parameter
-parameterA input
-parameterB1 input
-parameterB2 input
-parameterB3 input
-parameterC1 output
-parameterC2 output
-parameterC3 output
How to create a VI with a variable number of parameters?
Message 1 of 8
(5,878 Views)
You can't get the same "drag to expand" functionality as the in-built array functions have, but you can send the input parameters to the sub-VI as an array and get the output as an array. Just make the code inside the VI so that it will scale dynamically to the number of parameters given in the array.
Message 2 of 8
(5,878 Views)
Thanks a lot for your answer.
It could be a could improvement for the next versions.
I'll follow your advice.
Message 3 of 8
(5,878 Views)
Hi Nicolas,
As a continued effort to improve our products, NI has a Product feedback (suggestion) link on http://www.ni.com/ >> Contact NI >> Product Feedback.
Sincerely,
Feroz
Message 4 of 8
(5,878 Views)
Hi Feroz,
Any news with this topic?
Łukasz
Message 5 of 8
(5,388 Views)
Given that this thread is 8 years old, a lot of things have changed sice. What is wrong with the array solution given earlier?
(I am no expert here, but xnodes might be a possible solution but they are unsupported and undocumented.)
Anyway, the product suggestion center is now the LabVIEW idea exchange. If you think you have a good idea, feel free to post it.
Message 6 of 8
(5,381 Views)
Thank you for the reply. My first guess was that in case of arrays everything inside the VI should be closed in a loop and perhaps with varying number of inputs the loop could be avoided and this would improve simultaneous execution for multi-core CPUs.
Łukasz
Message 7 of 8
(5,239 Views)
I would not base all conclusions on first guesses. 😮
Working with arrays is typically significantly more efficient (e.g. SIMD). We also have the parallel FOR loop where several iterations can be executed in parallel, thus fully supporting simultaneous execution.
How exactly are you expecting the code to look like if you have a variable number of connectors?
Message 8 of 8
(5,235 Views)
