How to create a block diagram in Labview to measure the output voltage and convert to centimeters (Height measurement)?
Hello. My name is Alex here.
I am now facing a difficulty in creating a Labview diagram whereby the voltage that been created needed to be converted into centimeters.
I have been researching in the internet but to no avail. I need help in creating the diagram. Im using NI DAQ USB-6009 for the sensor and already wrote down the measurement.
Please help me. Thank you
(3,892 Views)
You can go through some basic materials in LabVIEW to get an Idea what can you do with LabVIEW (See the link provide here)
(3,877 Views)
Do you know what the conversion formula is?  I would recommend making a DAQmx scale and just make DAQmx do all of the work for you.
(3,869 Views)
You can use the attached VI as a sub-VI in your existing program.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,860 Views)
