How to create a chain of buttons?
Hi, I'm new to using labview and I want to create a simple program such that when a user selects a button another button would show up.
i.e. If user selects LED, then on the front panel 2 other buttons would appear to prompt the user which LED should be on. If the user selects motor, then 3 buttons would show on the front panel whether it is turning left, right or to stop it.
I was wondering if this is possible. If so, I was wondering how to go about doing this.
Thanks for the help in advance!
Message 1 of 10
(3,746 Views)
Accepted by topic author dragonite123
if you rt click on the buttons you wish to show on the front panel, create>property node.... there is a property call 'visible'. make these false upon initialization and then true when your LED or Motor buttons are true
Message 2 of 10
(3,738 Views)
Yes.  You would use property nodes of those other controls to set their visibility.
Message 3 of 10
(3,737 Views)
You could start working out with something like this. Hide the LED2 & LED 3 Controls in the front panel. When you start the program and click LED, the Othertwo buttons become visible.
Nghtcwrlr
Message 4 of 10
(3,727 Views)
Equal to True?  That's a Rube Goldberg.  Just wire the boolean through.
Assuming the other cases of the case structure have the same property nodes and just the other boolean value, then that is all a Rube Goldberg also.  Just wire th value into the property nodes directly, or wire a NOT function in in case you need to change True to False or False to True.
Message 5 of 10
(3,699 Views)
this all depends on whether it is a latch or switch
Message 6 of 10
(3,690 Views)
How do you figure that?  Please explain further.
Message 7 of 10
(3,687 Views)
ouch,my mistake...was not thinking
note to self: cut back on coffee
Message 8 of 10
(3,665 Views)
The LED is a Switch when released. No latch. thanks  for pointing out the  Rube Goldberg. I guess i was a bit high on coffee yesterday 😛
Nghtcwrlr
Message 9 of 10
(3,631 Views)
Thanks for all the help guys! 🙂
Message 10 of 10
(3,605 Views)
