How to create a database in SQL Server Express 2014 to be used with LV Database Toolkit
I use LV Database Toolkit, which by default uses Jet database. Now I want to use SQL database with LV Database Toolkit. I have downloaded and installed "SQL Server 2014 Express with Tools" in my Labview Laptop. Now I want to create a database in SQL Server, because I think it is a requirement for creating a "udl connection file" (*.udl file). Please help me!
Message 1 of 15
(8,956 Views)
Have you tried Google - http://msdn.microsoft.com/en-us/library/e38h511e(v=vs.71).aspx
You don't have to create a udl file, though. You can insert the connection string into the VI.
Message 2 of 15
(8,945 Views)
You can create a udl very easily, and if you want to, open it in a text editor to grab the connection syring.
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 15
(8,925 Views)
Creating database does not require UDL. UDL is needed to connect to the SQL server with LabVIEW. UDL file created  will have server name and credentials required to connect to SQL.
You can create database using queries fired from LabVIEW or you can go to SQL management studio and create a database and tables inside the database (With few right clicks and selecting appropriate options).
once database is created, then using queries you can do what ever you want.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 4 of 15
(8,903 Views)
Thanks to all who have devoted their Time! I have read all the sugestions and attachments, but I have still not tried anything to resolve my Issue. I have found 2 Articles on Microsoft Developer Network (which I have attached). The first one creates a database through "SQL Server Management Studio", which I will give a first try,if it is applicable to my case. The second is to run a Querry ("CREATE DATABASE TestData") from "LV Database Toolkit" That is supposed to create a database in SQL Server with the name "TestData"; I will give it a second try. Please keep on helping me further.
Thanks Again!
Message 5 of 15
(8,877 Views)
Hi!
In the last post I attached 2 Word 2013 document which can not be opened from previos versions of Word; so I am replacing with a website link of the 2 Articles.
SQL Management Studio: http://msdn.microsoft.com/en-us/library/ms186312.aspx
Create Databse through Querry: http://msdn.microsoft.com/en-us/library/ms365340.aspx
Please keep on helping me, because my issue has not made any substantial progress.
Thanks!
Message 6 of 15
(8,846 Views)
It's hard to understand what your issue is. Have you created the database in SQL Server? Have you created a UDL file? Both of these initial steps have nothing to do with LabVIEW.
Message 7 of 15
(8,834 Views)
I am thankful for the feedback of all the contributors. After reading all the sugestions and attachments in this thread, it is now to me completely clear how to make the database in SQL Server and then it is also clear to me, when I have the name and Path of my database, how to make the udl connection file. When these 2 things are done, I will be able to use SQL database instead of Jet database with LV database connectivity Toolkit. As soon as I have done this, I will post it.
Thanks for all the feedback!
Message 8 of 15
(8,819 Views)
In labview go to tools ->  create data link. ensure after cofiguring you should able to do test connection successfuly
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 9 of 15
(8,808 Views)
I made a database whose path is: C:\Program Files\Microsoft SQL Server\MSSQL12.SQLEXPRESS\MSSQL\DATA\depot1
I tried to make .udl connection file, but when I click on "test connection" with the provider: "OLEDB Provider for Microsoft SQL Server" I get the Error "UDL Connection File Failure" (attached below)
When I tried to make the .udl connection file with the provider "Microsoft SQL native Client 11.0" and when I click on "Test Connection" I get the Error" UDL Native Client_1"& " UDL Native Client_2".
Please help!
Thanks!
Message 10 of 15
(8,762 Views)
