For your functionality (If I understand it right), nothing needs to be in the event structure. Pressing any key just triggers the event, thus finishing the VI (there is no while loop).
Could you tell me what you mean my "it won't run properly"?
Make sure that the front panel of the subVI is closed before starting the main VI. Remember that the subVI is set to "open when called" and "close afterwards
if originally closed". So, if you had the panel open already, it won't of course close when finished!
(Actually, the problems is worse when you have the subVI panel open when starting the main VI. you get a catch22 and labVIEW locks up because (1) the subVI is set to dialog and grabs all attention but (2) it has not been
called, thus the event cannot be triggered. So don't do that!!!! As a quick workaround, add the modification shown in the attached image to ensure the panel of the subVI is closed.)
